I need help
Old Feb 20, 2020 | 09:07 PM
Dylanb187's Avatar
I need help
I recently bought a 94 5.0 when I bought it the blinkers and tail lights didn’t work but the break lights do work I’ve sorted through the fuses that could be blown and they were all fine. I’m not really that great when it comes to electrical problems what else could be the problem ?
Old Feb 21, 2020 | 06:28 AM
I had a caddy one time the turn signal bulbs were blown. I am sure you checked them already but if you didn't
Old Mar 13, 2020 | 03:31 PM
Poco's Avatar
If you have a meter you could check the actual connection to see if the pins are corroded. Also check your blinker switch...they tend to go bad.
Old Mar 18, 2020 | 04:16 PM
Gary Atkins's Avatar
Awhile back, for my sons first car, We got a '98 Mustang, and the signals didn't work. It was very simple to crack the steering column, and change out the turn signal module...worked for us.
Gigantor
Mar 10, 2017 10:31 AM
Zach89
Nov 18, 2014 05:33 PM
bud4au01
Sep 27, 2011 04:56 PM
rds1952
05-09 Exterior Modifications
13
Sep 11, 2011 03:31 PM
