How to remove stick on emblems
Old 6/27/04 | 06:37 AM
ronc09's Avatar
Hi I am getting ready to paint a 95 gt and was wondering if any one had an easy way to remove the stick on emblems with out causeing any damage to the body work or leaving too much of a goey mes behind. Ant tricks or tips would be great. I plan on buying all new embles for it so saving them is not a problem.
Old 6/27/04 | 07:08 AM
Redbaron93's Avatar
Use a hair dryer to soften it up then use a piece of fishing line and run it behind the emblem. You could probably peel it off with your hand if it gets soft enough. A little bit of alcohol will take off the glue.
Old 6/27/04 | 11:28 AM
JeffreyDJ's Avatar
Yup. It also helps if its a warm day to park it in the sun for just a bit, then get the hair dryer after it.
Old 6/27/04 | 12:43 PM
1 COBRA's Avatar
What has been mentioned above plus use hot water with car wash in it and a rag to remove any alcohol residue.
Old 6/28/04 | 02:54 PM
UA2k1GT's Avatar
i just used dental floss and goo-gone
Old 7/19/04 | 11:10 AM
ItsNotABulliT's Avatar
X2
Old 7/21/04 | 05:01 PM
BullittGt390's Avatar
when I had my old car I used something called "degreaser"...and i was laso getting it repainted
Old 7/21/04 | 06:51 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
hair dryer and 3m makes an adhesive remover that rocks! its a blue aerosole can.
10/2/15 02:00 PM
seaclam
9/25/15 02:29 PM
TMDM
9/24/15 08:00 PM
jim010
9/14/15 11:15 PM
9/10/15 01:44 PM
