HELP!!!! running rough
Old Dec 18, 2013 | 12:53 PM
Vader99's Avatar
Sorry for the long explanation, but here goes.
Ok, so my car has been drinking more gas than usual. So I cleaned the air intake, put a clean filter on, checked the spark plugs and changed them( they looked really old), and checked the fuel injectors. The #1 injector had a chip off of it right by the o ring that fell off when I pulled it out. So I got a new injector to replace it.
I get everything hooked back up and I get a misfire on #8. I checked all the plugs again, but it's still running rough. WTH? it seems to idle almost normal, but when I accelerate it's rough.
Oh btw, it's a '99 GT
Old Dec 18, 2013 | 01:36 PM
Vader99's Avatar
Am I crazy and just forgetting or overlooking something?
Old Dec 18, 2013 | 01:40 PM
AlsCobra's Avatar
A Man Just Needs Some....
#8 coil.
Old Dec 19, 2013 | 10:35 AM
Vader99's Avatar
Well I unplugged the battery and left it for a while. When I came back and hooked the battery back up the idle was still rough. I turned the ignition on and off several times and still no change. I think my multimeter may be bad. When I checked all the injectors and coils this morning I got no reading at all. So I figured what the hell I'll give it another try and suddenly it runs fine.
I'm convinced the odd ball injector was or is the source of the problem. As soon as I can I'm just going to replace all the injectors and coils
Old Dec 27, 2013 | 07:59 PM
mustang-muscle's Avatar
Also maybe u should check spark plug wires that sometimes are the problem.. But I've also heard of the coils going bad.
Old Dec 28, 2013 | 01:55 AM
fabien-france's Avatar
Hello , sorry to come in youre post but i want to know if have francophone personal on this forum ? Excuse me to asking that.have good day
Old Dec 28, 2013 | 12:29 PM
LivinTheStangLife's Avatar
Most likely a coil. Ford coils a lot of times just go bad. Sometimes you can ohm them and they ohm ok but still cause a misfire. If it happens again and shows what cylinder move that coil to another and see if it follows if so replace that coil pack. Also check the coil boot for cracks sometimes they'll just arc out a hole in the boot and cause your miss.
Old Dec 29, 2013 | 01:08 AM
Vader99's Avatar
I think it was just a loose connection. I unplugged everything then plugged it all back in making sure all connections were good and no more issues.
Old Dec 30, 2013 | 08:40 PM
ted2006's Avatar
no but we have spammers, dork
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 30, 2015 07:02 PM
