Help! H&R Sport Springs, Harsh Ride.
Old Oct 9, 2004 | 12:40 AM
DBBGT's Avatar
Long Post. 01 Mustang GT, originally had Bullitt springs with Bilstein shocks.
Changed over to H&R Sport Springs, reused the Bilsteins, new isolators all
around, and installed MM 4 bolt CC plates, 2 .5 inch spacers on top, both sides,
running Nitto 555 (stock size all around). Harsh ride, no suppleness at all,
every little irregularity in the road is fed back . :bang:
Old Oct 9, 2004 | 12:46 AM
DBBGT's Avatar
OOPs! 00 GT.
Old Oct 9, 2004 | 08:07 AM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
hmm.. have you checked to make sure your struts arent seized up somehow? the H&R's are a stiffer spring and are going to have a hader ride, but it shouldnt be so bad that it does that. You may need to check also into offset rack bushings for your steering.
Also i'm wondering if the way you put the spacers on the CC plates if you dont have it exact and its hitting the bump stop really easy in the struts.
Old Oct 9, 2004 | 12:36 PM
DBBGT's Avatar
Maximum Motorsports instructions said to use spacers on top of the
plate to equal the amount of drop of the spring, bit not so much as hit the
hood. Sports have a 1.5 inch drop, so one inch of spacers on top.
How do I determine if strut is seized, binding, or indeed hitting the internal
bumpstop? Thanks for replying.
Old Oct 9, 2004 | 11:20 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
go to each side of your car and push down. You should feel the strut compress and not really bottom out from you doing this. You may want to take it by your local 'stang shop (maybe hard on a rock in the middle of the ocean though) or somewhere that has a good rep for performance parts and have them take a look.
Old Oct 9, 2004 | 11:21 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
or if you take it to get it aligned (which you should do since you lowered it), the alignment guy should be able to give you a good solid opinion.
Old Oct 10, 2004 | 02:41 AM
NO2MORO's Avatar
Try using the Saleen springs. I have them on my 02 GT and the ride is better than stock. My brother was so inpressed that we ordered the same spring and installed them on his 98 Cobra.
May 3, 2026 05:42 AM
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
