Hawk break pads
Old Jan 23, 2010 | 02:02 PM
stang23456's Avatar
Hawk break pads
I added a set of Hawk Ceramic brake pads and power slot rotors to the front of my 04 GT. Ever since the install, im getting a sqeaking noise front the front while driving. When I apply the brakes, the noise goes away. Any ideas to what this could be ? I have checked to see if anything is rubbing and it looks fine.
Old Jan 25, 2010 | 11:44 AM
Miserable's Avatar
Warped rotor maybe?
Old Jan 25, 2010 | 11:13 PM
JedCranium's Avatar
Did you follow the "bedding" process for your pads & rotors?
Old Jan 26, 2010 | 01:16 AM
cntchds's Avatar
My thought exactly^
If you don't wear the pads in correctly they can get "glazed" and do not provide much stopping power. What you can do is take some sand paper to them and bed them properly. If this doesn't work, I don't know what to tell you.
Old Feb 6, 2010 | 05:17 AM
lsanch33's Avatar
fixed?
I am having this same problem on my 01 Bullitt left front wheel . . . . cruising-> noise . . .. . .riding brake -> nothing . . . . . . . any progress for you? in the next couple of days I am going to get under my car to investigate mine . . . .
Old Feb 6, 2010 | 11:57 AM
wheel bearing? anti-squeal plates?
Old Feb 7, 2010 | 08:58 AM
lsanch33's Avatar
Would a bad bearing noise go away when riding the brakes? I personally do not have obvious play in my noisy wheel. . . . . hopefully I will get time today to investigate mine a little more, I am going to pull the caliper off and see if the noise is coming from the bearing . . . . Thanks for the info . . .. . does anyone know what type of open headed nuts I need to buy for the Mustang? I want to pull the wheel off and tighten down the rotor . . . . .
Old Feb 10, 2010 | 12:18 AM
cntchds's Avatar
1/2 x 20? I think... Regardless, there should be far less play in the rotor itself than the whole wheel, since in essence they should be moving exactly the same but since the wheel is physically larger, the wobble would be proportional to the size of the object you are wiggling (wheel:rotor)
Old Mar 21, 2010 | 06:12 PM
stang23456's Avatar
any luck with brake noise ! Mines still there
Old Mar 31, 2010 | 03:02 PM
m4reapr's Avatar
Originally Posted by Miserable
Warped rotor maybe?
no, he would have pulsating brake pedal plus rotors are new
rotor is held on by the wheel, not anything between the two, the open headed nuts you are referring to are the wheel studs
not likely the wheel bearing if not constant noise, it is a self contained bearing assembly. if you can move the wheel by grasping top and bottom and rocking toward and away from you it's needing replacement ~$70 apiece
anti-squeal grease to the backs of the pads contacting the pistons will probably cure this
kponypower
Jun 17, 2020 07:17 AM
Gill5oh
Oct 6, 2017 10:50 PM
Fedupdave42169
Sep 22, 2015 06:29 PM
5.M0NSTER
Sep 16, 2015 08:00 AM
