Has anyone replaced their water or oil pump
Old Sep 12, 2011 | 06:29 AM
If you have what kind of milage was on it? I'm rebuilding an engine and I am considering replacing them but just not sure if I should spend the cash on them..... Its a now or later deal I guess.
Also have you had to replace any sensors?
Old Sep 12, 2011 | 06:35 AM
Onesickstang01's Avatar
Oil pump wouldnt be a bad idea since you are in there already. Water pump is an easy job you can do anytime without removing anything except the belt
Old Sep 12, 2011 | 06:45 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Whenever I build an engine I always replace the oil pump. The part isn't that expencive and it is not worth the few extra bucks you save and then have rod and main bearings spin. Water pump isn't as big adeal cause its easier to change and it wont destroy the engine if it fails. But you do not want to risk the new bearings on an old pump.
That is of course you enjoy building your engine over and over
Old Sep 12, 2011 | 10:16 AM
That is pretty much what I was thinking but I also want to see how well they are holding up for other people. I have read about very few failures with these two items.
Old Sep 12, 2011 | 10:26 AM
Bear Eats King...
Bear ****s Bone
They don't fail often but why risk it on a rebuilt engine?
Old Sep 12, 2011 | 10:57 AM
If you're doin' it, do it right.
Old Sep 13, 2011 | 05:27 AM
of course. I'm sure mine is full of bearing dust and metal particles. Just wondering how many have had to replace theirs. I've heard of very few failures between the oil and water pump. They don't make them like they use to. Thank God Fyi the oil pump is mounted to the front of the engine. I am putting a oil pressure gauge in before I restart the new engine.
Old Sep 13, 2011 | 08:15 AM
Yea the oil pumps are made to go for a lot of miles these days. Water pumps not so much but i cant say ive done many on 4.6s. Gm and dodge vehicles are another story. The worst of all are the gm 4 cylindrr cars. You want to replace oil pump any time there is any bearing damage, low oil pressure, ect. Its not like the old days you could pull an oil pan with the motor still in the car and replace it. Make sure you pull the fuel pump relay before stafting the motor and turning it over so you can prime the motor
Old Sep 16, 2011 | 06:47 PM
Ordered a high flow oil pump from american muscle. 45 bucks delivered. not bad at all.
lakersfreak
Jun 13, 2022 12:29 AM
kponypower
Jun 17, 2020 07:17 AM
trackpack13gt
Oct 2, 2015 08:20 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
