Foglight question..........
Old Jan 21, 2005 | 10:53 AM
XLR8's Avatar
Hey guys......I was wondering if anyone would know why one of the foglights on my '02 GT is dimmer than the other one. I changed the bulb out thinking that maybe it was bad but it is still significantly dimmer than the other one. Has anyone ever encountered this problem before? Any ideas on how to fix this?
Old Jan 21, 2005 | 11:08 AM
SoCalCobra311's Avatar
is the bulb in tight? any wires loose or possibly damaged?
Old Jan 21, 2005 | 11:39 AM
Fordracing200's Avatar
It might be a dirty light? If it is clean both lights and then look at it again, and check all the wiring connections. Try the bulb first.
Old Jan 26, 2005 | 09:04 PM
Badsnke98's Avatar
Most likely water and dirt got in the houseing and the reflector material is damaged. That is what has happened on my sons 01 GT on the passenger side. You can order just the houseing for $19.95 from 5.0 Restro.
Stang281
05-09 Exterior Modifications
Oct 30, 2006 02:33 PM
steevr
Aug 2, 2006 08:21 PM
