feeding an supercharger
can you help please
if your running a supercharger do you need to change your injectors and fuel pump and if so what size?
and what is relatively safe amount of boost on a pretty much stock 94 gt and what can you get away with once in a while?
many thanks in advance
Stubborn Bear
TMS Staff
TMS Staff
Yes, pretty much with any supercharger or turbo setup, you are changing out the injectors and pump, and usually MAF as well. With more air, you need more fuel.
On a stock 94GT, i'd say no more than 8-10lbs of boost to be safe. But with any forced induction, dont get the tune right, you can blow the motor on even 2lbs of boost.
JonathonK
9/19/15 03:19 AM
9/8/15 10:45 AM
