Estimated horsepower gains?
Old Oct 14, 2012 | 03:36 PM
White94GT's Avatar
Ok I had my car dynoed in May and it dynoed at 310rwhp, and I'm upgrading a few things and just wanted to see what you guys think the gains will be , roughly ?
I'm changing :
BBK cai to the JLT cai
24lb injectors to 30lb injectors
75mm MAF to 80mm MAF
Edelbrock RPM upper to edelbrock RPM II upper
BBK equal length headers to BBK longtube headers
Old Oct 14, 2012 | 06:18 PM
Knight's Avatar
Needs to be more Astony
Same dyno? If so, maybe 10-20rwhp.
If its a different dyno then it could be higher or lower than before.
Old Oct 14, 2012 | 07:13 PM
White94GT's Avatar
Yea same shop same dyno!
Old Oct 14, 2012 | 07:29 PM
skunk21's Avatar
dyno #'s really differ from dyno to dyno and day to day like stated. the biggest gains would be from the long tubes over the shorties and smaller gain in the intake over the current one, since you have a decent flowing aftermarket intake and going to another one with more flow capabilities. think of it like going from 3.08s to 4.10s vs 3.55s to 3.73s. one you notice alot the other not so much.
you have a modded motor that is pushing about what a really good h/c/i n/a would make rwhp wise, you are getting to it's limits. like Knight stated you will net some small gains but really the next move is boost ( like the low boost set up you want to do or aftermarket block and big boost/turbo) or cubes ie 347 or 351 and stroking that to like a 408 or something along those lines.
Old Oct 14, 2012 | 09:33 PM
White94GT's Avatar
Well put together , yea I found a Vortech v-3 Si-trim 6psi supercharger or $2,100 , I think that may be my best bet
09-gt/cs
Oct 15, 2015 10:03 AM
Bryanh24
Oct 14, 2015 08:43 AM
GLOCKer
Sep 28, 2015 05:20 PM
