Engine stalling problem.....
Old Feb 19, 2005 | 06:42 PM
00StangGT's Avatar
ok my car is acting really weird. When it's cold out and I take it out, to say subway or something, it sometimes just dies wile driving.
This happens when I am putting on the brakes slowing down and have the clutch in to shift. I will feel the steering go hard and a hard brake pedal.
I can start it up and drive away fine but it happened 2 times yesterday and 3 times today withing 20min of each other.
The IAC has been replaced 2 times under Ford warranty and they tightened up the ground wires for my ECU cause they thought that a wire was shorting it out since it was loose.
Old Feb 19, 2005 | 07:43 PM
André's Avatar
Had a similar problem, irratic idle speed and the car would stall coming to a stop and on occasion would not restart, the dealer did not have a clue and changed the fuel pump and IAC for nothing, only after I insisted they change the crankshaft position sensor was the problem fixed, could be something else of course but have that checked...
Old Mar 31, 2005 | 07:26 AM
00StangGT's Avatar
ok I figured it out.....the source finally showed itself. I was driving home (2.5hrs) for spring break and my temp gauge never came above the first set of three dots.
Come to find out I have a bad thermostat that sends my engine into a open loop and would just run rich flooding my engine making it stall at random.
Fixed that and not a hiccup since!! yay!
Old Mar 31, 2005 | 09:59 AM
conv_stang's Avatar
cool. glad you figured it out
Old Apr 2, 2005 | 07:30 AM
Nuts4Ford's Avatar
hmm Thermostat. Well I got me another part to check on my similar problem... Glad you figured yours out
Road_Runner
Sep 2, 2024 04:46 PM
Uofmrampage
Aug 2, 2022 02:55 PM
trackpack13gt
Oct 2, 2015 08:20 PM
