Coolant leak.
Old Dec 19, 2013 | 01:55 PM
Fastang97's Avatar
Coolant leak.
Coolant is leaking right behind the intake manifold. Anyone know what that part is called??
Old Dec 19, 2013 | 02:28 PM
LivinTheStangLife's Avatar
Pictures?
Old Dec 19, 2013 | 02:57 PM
Fastang97's Avatar
It's too hard for a pic. It is on the left side. Doesn't seem to be the intake itself. Does heater core sound good??
Old Dec 19, 2013 | 03:47 PM
Heater core is under the dash on the inside of the car. 97? GT or v6? I have a mach 1 so I'm not familiar with the sohc 4.6 since I have the dohc. But I have a 3.8 as well. I'm just trying to picture what would be behind the intake. Well the heater hoses would probably run back there going into the firewall to go to the heater core. Leak up high or low?
Old Dec 19, 2013 | 05:35 PM
Fastang97's Avatar
Up by a hose. Thanks for trying though
Old Dec 19, 2013 | 07:54 PM
If it were coming from the front I'd venture to say it's probably a crack along the thermostat portion of the intake. The manifold's on the 4.6s are total plastic crap, but try a bottle of Barr's StopLeak. It's not a permanent fix, but it gets the job done unless you've got a big leak.
Old Dec 29, 2013 | 09:28 AM
td01gt's Avatar
hey, did you get this problem fixed? If not it is the nipple for the heater hose on your intake. common problem with the plastic intake.Probably going to have to replace whole intake.
Old Feb 6, 2014 | 05:25 PM
Fastang97's Avatar
++++++ Bingo lol. Replaced the intake manifold and got new injectors. Runs like new and no LEAKS! :-)
unnoticedtrails
Jul 17, 2017 11:10 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
NC14GT
Aug 2, 2015 07:27 AM
Michael Follett
Jul 24, 2015 06:58 AM
