Clutch plan for turbo
Old Apr 2, 2013 | 10:44 AM
staakattack's Avatar
So I'm in process of a turbo build on my 95 cobra and all I need is a meth kit and the build will start....now my question is I still have the stock clutch in but it grips right away, never slips. I have full bolt ons with an SCT chip/bama custom tune...long story short I always hear why replace something if it ain't broken....so should I keep the stock clutch for build until it burns out or just upgrade now....opinions please?
Old Apr 2, 2013 | 10:47 AM
1999Pony's Avatar
I would upgrade it. You might be able to get by for a while, but one good launch and you'll be getting a tow home. Don't fix it if it ain't broke, but also make sure all your components can handle your mods. The stock clutch isn't going to last long with a turbo setup.
Old Apr 2, 2013 | 12:07 PM
Knight's Avatar
Needs to be more Astony
You will need a clutch. its not all about starting grip. you need grip once clutch is engaged too. As soon as you get into boost most likly you will over power your clutch and it will slip.
Old Apr 3, 2013 | 05:38 AM
Ok fair enough. I already have a brand new ram HDX in the box that I plan on using. But for the break in of the new clutch would it be bad to get dyno tune on a fresh clutch? I just figure it'd be easier and save a bit of time to do clutch and do the turbo at the same time and just go real easy on the clutch for the next 500miles or however long it takes...
Old Apr 3, 2013 | 09:16 AM
AMDanBailer's Avatar
Former Vendor
I agree with the above statement. With the added Power and Torque from a Turbo set up, you're definitely going to want a heavy duty clutch so that you can actually put that power down! I would probably recommend putting some kind of miles on the clutch before letting it rip on the Dyno. Just so that it has a chance to break in a bit!
I hope this helps. Please let me know if you have any questions or need some assistance!
-Dan
Old Apr 3, 2013 | 12:07 PM
Sounds good. Also is there a hp/trq limit for flywheels? I plan on just resurfacing my stocker and throwing it back in and I've heard there is nothing wrong with that and even seen people suggest it in other feeds
Old Apr 3, 2013 | 12:30 PM
AlsCobra's Avatar
A Man Just Needs Some....
Doesn't matter what clutch, that motor won't last long enough to outlive any clutch you put in there. Turbo 302 for more than a drag car will eat your lunch.
Old Apr 3, 2013 | 02:08 PM
Knight's Avatar
Honestly I wouldn't take chances on resurfacing the flywheel. I say if you are going to do turbo and new clutch than do it right. Get a new flywheel with the clutch. No chance of bad surfacing or unevenness ruining the clutch break in.
Old Apr 11, 2013 | 07:48 AM
Also what kind of tranny fluid should I use with it?
Autotooner
Nov 24, 2017 12:42 PM
Gill5oh
Oct 6, 2017 10:50 PM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
GeoWett
Sep 30, 2015 06:40 AM
