Cigarette lighter
Old Jul 20, 2013 | 09:10 PM
McNassty's Avatar
Cigarette lighter
Does anyone know where I could get something where i could delete my cigarette lighter and mount my chip switch? I have a 1995 Cobra
Old Jul 21, 2013 | 03:09 PM
McNassty's Avatar
Bump
Old Jul 21, 2013 | 06:13 PM
BA Mustang's Avatar
Probably would have to make it.
Old Jul 21, 2013 | 07:41 PM
AzPete's Avatar
lf you remove the cig. lighter you should be a should be able to find a couple of washers that are big enough to cover the hole and still fit the switch. I have used fender washers on some. A bit of paint and it is done.
Old Jul 21, 2013 | 08:20 PM
McNassty's Avatar
Kay, thank you guys. It really sucks, I was hoping there would be a part out there that I could buy for this
Old Jul 21, 2013 | 09:15 PM
AzPete's Avatar
There are kits that allow you to install a push button start in numerous models of cars using the cig. lighter location. Might see if you can find the right type switch because the start button is momentary on only and you most likely need a push on...push off.
Old Jul 21, 2013 | 10:57 PM
McNassty's Avatar
No I need a selector dial type mount
Old Jul 22, 2013 | 07:49 AM
AzPete's Avatar
Ok....is there enough room in the back to fit the switch? I would just take your switch and a couple of fender washers and sandwich the hole of the cig lighter between the washers. Pretty easy to do plus a touch of paint.
Feb 10, 2017 07:12 PM
CiniZter
25
Apr 28, 2016 05:41 PM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Mr. Sparkle
Sep 2, 2015 10:13 AM
MRGTX
Aug 21, 2015 08:49 PM
