Check Engine Light Reset
Old Jan 18, 2005 | 03:11 PM
SoCalCobra311's Avatar
My wife drove home today from the gas station with the floor door shut but the cap was haging from the outside. As you guessed the gas pressure was showing the gauage on empty. Now as I expected the Check Egine Light is now stuck on. Is there anyway I can reset that without having to take the stang into Ford?
Old Jan 18, 2005 | 06:41 PM
Fordracing200's Avatar
put the gas cap on and make sure it clicks 4 times, and it should reset itself in a few days, if its not right by the end of the week go to the dealer
Old Jan 18, 2005 | 07:00 PM
sounds good thanks
Old Jan 18, 2005 | 07:15 PM
No problem, worked on 2 of my cars....
Old Jan 18, 2005 | 09:09 PM
dfhurleydude182's Avatar
Another alternative should be reseting the battery. If the check engine light does happen to come on again though, it might not be the gas pressure issue.
Old Jan 18, 2005 | 11:19 PM
Scothew's Avatar
Stubborn Bear
TMS Staff Retired
I agree with dfhurley. Unplug the negative battery cable from the battery for about 5min. Also touch the brake pedal breifly after the battery is unplugged to discharge any juice stored in the ECU. Then plug it up, reset your radio stations and watch for anymore signals.
Old Jan 18, 2005 | 11:41 PM
alright, because i catch myself looking down and being suprised seeing the CEL everytime like its the first time I'v seen it. Drives me crazy
Old Jan 20, 2005 | 04:02 AM
jgsmuzzy's Avatar
I thought it was on to illuminate the dashboard (mine's been on for 8 months!!). If it starts to flash, that's a real problem, right?
Old Jan 20, 2005 | 01:40 PM
LMFAO!
Old Jan 20, 2005 | 08:37 PM
when i drive at night its reflects off my dashboard onto the windshield like an Apache Helocopter Heads Up Display
Old Jan 26, 2005 | 07:35 PM
Unplugged the battery pumped the brake and waited about 10 mins. Fired up the stang and was good to go. All my stations were saved and so far 3 days later no CEL.
Ecostang
Nov 3, 2022 08:50 PM
Lake_Vert
Aug 11, 2015 06:40 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
