Check Engine Light Reset
My wife drove home today from the gas station with the floor door shut but the cap was haging from the outside. As you guessed the gas pressure was showing the gauage on empty. Now as I expected the Check Egine Light is now stuck on. Is there anyway I can reset that without having to take the stang into Ford?
I agree with dfhurley. Unplug the negative battery cable from the battery for about 5min. Also touch the brake pedal breifly after the battery is unplugged to discharge any juice stored in the ECU. Then plug it up, reset your radio stations and watch for anymore signals.
ClayP
Aug 11, 2015 06:23 AM
