Brakes stuck?
Brakes stuck?
I have my 2002 mustang gt. I just replaced the front brake pads and rotors. When re compressing the pistons I found that they were really stuck and I had some trouble getting them in, but I got em. But driving it around the next day I found that it felt like the brakes were still partially on even tho I wasn't pressing the pedal, like when I went out my foot down in 5th it didn't accelerate and just stayed the same speed, and when I went to start moving at a light the car has some trouble getting going. What could be wrong and how could I fix? Feels like the brakes are stuck and holding the car but how do I check? Thanks
Pistons can get stuck in the bores of the calipers on these cars. Once that happens, you are talking either a rebuild or a replace, as they won't retract.
You could have a caliper pin that isn't lubricated or whatever, and that will stick the caliper as well.
Rebuild the caliper (example!):
I had a sticky piston on my passenger rear caliper in my 95. I unscrewed the piston, emptied the caliper of fluid, and replaced the piston with a new one. Works fine now. My slider bolts also seized from lack of re-lubrication. Apparently another common issue. Something you could check out.
I have my 2002 mustang gt. I just replaced the front break pads and rotors. When re compressing the pistons I found that they were really stuck and I had some trouble getting them in, but I got em. But driving it around the next day I found that it felt like the breaks were still partially on even tho I wasn't pressing the pedal, like when I went out my foot down in 5th it didn't accelerate and just stayed the same speed, and when I went to start moving at a light the car has some trouble getting going. What could be wrong and how could I fix? Feels like the breaks are stuck and holding the car but how do I check? Thanks
I had the same problem you had, with the pistons being hard to compress.
So, I put the front up on jack stands, and tried to spin both front wheels, and no way. I could move them by hand, but they wouldnt spin freely. I ended up replacing the calipers, the soft hoses, rotors, and added new ceramic pads.
Come to find out, the calipers are aluminum, and the pistons are "phenolic", which is a fancy way of saying plastic...If I ever do another brake job, it will be to add the Baer big brake kit, and get rid of very poor Ford components.
But that was a 1 1/2 years ago, and they are still performing flawlessly.
Nope. Just shove 'em in with a brake pad and a c clamp or whatever does the job.
Acually, Ford recommends a c clamp... Go figure.
Replaced the front callipers and the car performs great. Along with the new pads and rotors the cars brakes feel better then they ever have before. Little bit of a pricy matanence even tho I did it myself. Still feels great to be back up and running!
Jun 14, 2016 06:30 AM
