bbk 78m intake?
Old Aug 5, 2012 | 11:09 PM
larrystang's Avatar
bbk 78m intake?
If I install a bbk 78m throttle intake would I have to install bigger injectors because I'm I will b giving it more air than fuel including with my bbk intake kit??
Old Aug 5, 2012 | 11:51 PM
cpotts13's Avatar
78mm is to big for a car that isn't heavily modified or f/i
Old Aug 6, 2012 | 02:56 PM
larrystang's Avatar
So Wat if its tuned?
Old Aug 6, 2012 | 07:27 PM
Tommy d's Avatar
I just got the 78 bbk intake the other week and its tuned by blown by racing it runs very good but my future plans are nitrous and the guy a bbr said that 75 is the most you wana go with na
Old Aug 6, 2012 | 07:57 PM
cpotts13's Avatar
Something like that.
Old Aug 7, 2012 | 12:55 AM
larrystang's Avatar
Oh ok i haven't seen 75m but ill look them up
Old Aug 9, 2012 | 07:46 AM
Knight's Avatar
Needs to be more Astony
if you are planning on doing other mods than the bbk 78mm would be a good start. You would not need larger injectors at this point, you may not notice any gain in power with just the bbk but it is something you would want in the future with other mods.
the stock 19lbs/hr injectors should be good up to around 290-300rwhp and it takes quite a lot of mods for a 2v to put that down.
Old Aug 10, 2012 | 07:52 AM
larrystang's Avatar
So ill b like a waste of money if u would buy dat cuz I wouldn't get any good results?
Old Aug 10, 2012 | 09:45 AM
1999Pony's Avatar
Its more like a supporting mod. Its not going to really give you any gains on a shock engine, but as you get more heavily modded, it will more and more come into play.
That being said, until you get more modded, there's not reason to get it.
Old Aug 10, 2012 | 10:29 AM
Knight's Avatar
I dont think its a waste of money, its actually a great deal since you are able to upgrade the throttle body and intake plenum all in one rather than buying them separate. I'm just saying dont expect a huge gain until you start getting other parts.
If you can afford to do exhaust at the same time you will feel a noticeable gain. Offroad x-pipe really helped my 99 gt.
Old Aug 10, 2012 | 02:51 PM
Falco_03GT's Avatar
You might be alittle sluggy off the start but there will be little higher end gains.
Old Aug 12, 2012 | 09:48 AM
WheelStander's Avatar
I installed the 78 and it runs strong in all ranges with cai, exhaust and tune Had tune done a couple years ago. Installed 78 last year and it runs perfectly without another tune.
The throttle response improvement was huge and car runs great in all temps.
I recommend it.
Old Aug 12, 2012 | 07:39 PM
larrystang's Avatar
I recommend it.
Wats cai?? So it should run good after a tune..?
Old Aug 12, 2012 | 07:48 PM
SilverSkoundrel's Avatar
Cold air intake
RoushRS3
Sep 29, 2015 08:03 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
