98 cobra imc problem
Old Jun 27, 2011 | 09:03 PM
VENOMOUS ONE's Avatar
Bank 1 not opening 64000 miles need cleaning or replace need help. Not opening in high rpm
Old Jun 27, 2011 | 09:21 PM
harristotle's Avatar
You getting the check engine light for it? Worst case scenario the control module is faulty which is expensive if I recall.
It's not uncommon for the 2nd set of intake valves to get caked due to not having a fuel injector before it to blast em off.
Here's the cleaning how to that I printed off a while back. http://www.svtmustangcobraclub.com/m...C_Cleaning.pdf
I had always planned on doing it as mine would throw the code every once in a while, but just haven't ever gotten around to it. Hope this help!
Old Jun 28, 2011 | 09:14 AM
conv_stang's Avatar
what kind of modifications do you have?
Modular Mustang Racing www.modularmustangracing.com sells an IMRC delete kit.
All billet, awesome. Used them on my engine build. Im sure I lost a little down low, but with my gearing ill never feel it. And is a definite need for top end power.
96-98 Cobra / Lincoln Mark 8 IMRC Deletes
These Billet Aluminum plates from MMR delete the factory plastic or cast aluminum IMRC (intake manifold runner control) which can cause an airflow restriction and a loss of HP along with "gunking" up the port without the injector which leads to valve guide wear, smoking and oil usage. The plates can be ported and are great for all naturally aspirated and supercharged applications with big HP gains in the upper RPM level. Direct bolt on!
Old Jul 3, 2011 | 10:39 AM
Can the imc get cleaned without the tear down. Like seafoam , Lucas or something. Let me know. If not imc cleaning here we come.
Old Jul 3, 2011 | 10:42 AM
Bbk cold air, bassani xpipe ,msd tune up an coils. The rest is stock
Old Jul 3, 2011 | 12:22 PM
It's possible, but it's just going to delay the inevitable. Seafoam is the route I went, but at some point mine will still need to be cleaned.
Heck just the cloud of smoke from the Seafoam is worth doing it
Old Aug 12, 2012 | 09:24 PM
How much were the imrc deletes. I'm thinking that's the way I want to go. Anything else needed with them.
Old Aug 12, 2012 | 09:37 PM
I have a bassani xpipe no cats,cold air intake,msd plugs,wires,coil packs,bbk fuel pump,bbk fuel pressure regulator,center force duel friction clutch.after the new deletes anything u recommend to make her faster 98 cobra.also have panhar sway bar from maxiam motors,lowered in the front,steeda short throw shifter.
Rando
Aug 25, 2021 11:12 AM
Autotooner
Nov 24, 2017 12:42 PM
trackpack13gt
Oct 2, 2015 08:20 PM
blackhawkkid308
Sep 30, 2015 04:04 PM
Ray11
Sep 25, 2015 12:43 PM
