Awful Gas Mileage
Old Mar 27, 2012 | 03:59 AM
cntchds's Avatar
Awful Gas Mileage
Since I did my head gasket swap I have been getting atrocious mileage. Is there any thing I could have done wrong on the reassembly that could cause me to be getting 15 MPG when I used to get between 18 and 21? I have been going super conservative on this tank and I'm still burning through gas much faster than I ever have before. My AC also stopped working. I doubt it is connected, but maybe it's dragging the engine? Help. :-(
Old Mar 27, 2012 | 05:27 AM
cpotts13's Avatar
I get an average of 15 mpg.. and my cars fine...
Old Mar 27, 2012 | 05:34 AM
1999Pony's Avatar
Its possible if your compressor is locked up, then the motor could be working harder to turn the pulley on the compressor and that could be causing it. You might have a vacuum leak somewhere which could also be the culprit.
Old Mar 27, 2012 | 10:55 AM
cntchds's Avatar
Really? That's as bad as I got in my 94.
Old Mar 27, 2012 | 10:56 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Connected the egr back correctly? No vacuum leaks?
Old Mar 27, 2012 | 11:42 AM
skunk21's Avatar
My thoughts. vacuum leak or something isn't hooked right. also how long did you run it with bad gasket? did it swallow alot of coolant? might have a hurt cat jus not dead enough yet.
Old Mar 27, 2012 | 02:52 PM
cntchds's Avatar
I didn't lose much coolant. Maybe a pint? Vacuum leak is a possibility but I can't hear it anywhere.
Old Mar 27, 2012 | 02:55 PM
Bear Eats King...
Bear ****s Bone
Idle speed? Cel?
Old Mar 27, 2012 | 06:33 PM
1999Pony's Avatar
To be honest, I get between 16-18 in my sixxer and around 15 in the 95. Of course I beat the **** out of the sixxer, but that beside the point.
Old Mar 27, 2012 | 06:40 PM
11SHELBYGT500's Avatar
LOL I get 18 in my 500. LOL
Old Mar 27, 2012 | 06:44 PM
tacbear's Avatar
Mileage is about 22 city 27 Highway. I have gotten as low as 15 open tracking.
Attached Thumbnails Awful Gas Mileage-100_3092-medium-.jpg   Awful Gas Mileage-improvedpic3-medium-.jpg
Old Mar 27, 2012 | 07:11 PM
skunk21's Avatar
I got in the 20's easy before the gear change but I still get better than 15mpg cruising. I would run a scan on it anyways.
Old Mar 27, 2012 | 07:15 PM
1999Pony's Avatar
Yeeeaaaaaaa
Old Mar 27, 2012 | 07:19 PM
Yeeeaaaaaaa
That sounds like you don't believe me. LOL
Old Mar 27, 2012 | 08:20 PM
1999Pony's Avatar
No i believe you just fine, its more an admittance on how terrible mine is.
Old Mar 27, 2012 | 09:08 PM
01GT's Avatar
I get 12 city and around 15 high way.
Old Mar 27, 2012 | 11:58 PM
cntchds's Avatar
Idle speed is steady between 700 and 800 RPM. No CEL.
Old Mar 28, 2012 | 07:31 AM
skunk21's Avatar
Hmm. Then put your foot on a diet.
Old Mar 28, 2012 | 02:49 PM
cpotts13's Avatar
That's asking a little to much!!
Old Mar 28, 2012 | 08:24 PM
bluethunderhorse's Avatar
Quick way to check for a vacuum leak, is to spray wd40 around the mating surfaces. If you hear any change in the way the engine runs, in any certain place then you've narrowed your search.
