Awful Gas Mileage
Awful Gas Mileage
Since I did my head gasket swap I have been getting atrocious mileage. Is there any thing I could have done wrong on the reassembly that could cause me to be getting 15 MPG when I used to get between 18 and 21? I have been going super conservative on this tank and I'm still burning through gas much faster than I ever have before. My AC also stopped working. I doubt it is connected, but maybe it's dragging the engine? Help. :-(
1 Post
Its possible if your compressor is locked up, then the motor could be working harder to turn the pulley on the compressor and that could be causing it. You might have a vacuum leak somewhere which could also be the culprit.
Originally Posted by skunk21
My thoughts. vacuum leak or something isn't hooked right. also how long did you run it with bad gasket? did it swallow alot of coolant? might have a hurt cat jus not dead enough yet.
1 Post
Originally Posted by cntchds
Really? That's as bad as I got in my 94.
Originally Posted by 1999Pony
To be honest, I get between 16-18 in my sixxer and around 15 in the 95. Of course I beat the **** out of the sixxer, but that beside the point.
Quick way to check for a vacuum leak, is to spray wd40 around the mating surfaces. If you hear any change in the way the engine runs, in any certain place then you've narrowed your search.
