AC Pressure Line
Old Apr 24, 2007 | 06:59 PM
ndubya's Avatar
AC Pressure Line
Has anyone had to repair (don't even know if its repairable) or replace your AC pressure line coming from your radiator? Somehow it melted from the heat of my CAI heat shield.
Old Apr 26, 2007 | 12:45 PM
dhg2496's Avatar
Got any pictures of the problem? I don't think your cold air would have gotten hot enough to melt any AC Lines. If the heat shield was pressed against it, then maybe it rubbed against it too much and broke through it.
Old May 5, 2007 | 02:51 PM
hamstang58's Avatar
If the pressure line is damaged, it's best to replace it. The pressure line must be able to withstand pressures up to 500 psi.
Old May 6, 2007 | 08:58 PM
mr_speedvision's Avatar
If you have a k&n I know exactly what you're talking about... you rubbed a hole in the aluminum line. It can be repaired, but you really need to have the system evacuated. I cut the line where the factory orifice tube was installed (you'll see a crimp in the line) and installed a replacement orifice housing. It uses compression fittings and was long enough to cover the damaged portion. I replaced the refrigerant oil and refrigerant with no hang-ups. Hope this helps. Oh by the way I purchased the parts from O'Reilly auto. You can find the parts in the Murray catalog. They were off the shelf items, and in stock. A good parts person should be able to help you out...
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Sep 8, 2015 10:45 AM
