98 cobra problems
Old Jan 12, 2016 | 07:27 PM
heydielove's Avatar
98 cobra problems
I own a 98 cobra just had a engine light come on when to AutoZone they said oxygen sensor driver side front before cat so I did that ... Did not fix problem anyway car is bucking at 2000 to 2500 AND rough idle at start sometimes stalls to .... Wanna fix and all help much appreciated thanks
Old Jan 13, 2016 | 03:02 PM
Jim74656's Avatar
after replacing the sensor did you have the light/ecu reset to clear the DTCs? run the car for a bit and see if the issue comes back, if so rescan for codes.
Old Jan 23, 2016 | 05:06 PM
heydielove's Avatar
I did not reset DTC's or ECU. I unplugged the battery installed the sensor plugged it back in , with battery toke it down the road for 20min and its still bucking...
Old Jan 25, 2016 | 10:36 AM
Jim74656's Avatar
Try having the light/ecu reset by a shop (or if you have your own code reader do it your self) and then repeat, in some cars removing the negitive battery terminal will not reset the ECU effictively, if we can get the codes cleared first and test with a "clean" ecu that will help us determine where to go, and what codes (if any) will help determine the real issue, instead of throwing parts and guesses at the issue...where about are you located?
techforay
Dec 18, 2024 07:25 PM
dj050894
Jan 31, 2016 06:18 PM
thatmustangguy89
Jan 16, 2016 04:36 AM
mustang09girl
Jan 13, 2016 04:57 AM
oceantracks
Jan 8, 2016 07:24 AM
