Wet carpet on driver side floorboard
Old Jan 11, 2016 | 08:58 PM
techforay's Avatar
I understand that there can be a problem if drains below windshield get plugged. Water can come in through the filter that primarily affects the passenger side of a 2005 - 2009 mustang. That is not what is happening to me. Both drains are unplugged. I just bought the car so i am not sure if the previous owner unplugged them or not. My problem is on the driver side. The carpet and pad under the matt is wet and deteriorated. It looks like its been happening for a while. Is there a common problem with water on the driver side that anyone has experienced. Any good methods for determining where the water is coming from?
Old Jan 12, 2016 | 05:50 AM
05YellowGT's Avatar
It can leak in numerous places, do a search for TSB 08-26-7 and it'll show you where.
Old Feb 4, 2016 | 06:44 PM
ford4v429's Avatar
legacy Tms Member
I just added a few pics of trouble spots in the last couple posts here-> https://themustangsource.com/forums/...469258/index5/
Old Mar 12, 2016 | 09:40 AM
apjones252's Avatar
Leaks are most commonly known on the drivers side to come from a leaky firewall or more commonly convertible tops, do you have a convertible? If not than I'd pull up the carpet on that side and look for rust/cracks/holes/ unsealed line holes and maybe even check the lower front corner of the door. How does water run down it when you spray it with a hose, if it pools up in the crack or seams like it goes in than its probably squeezing through crack on the plastic and down into the carpet. It's just the drivers side right? Hopefully that'll help you a little for finding it, but good luck once you do, I hate wet floors. Intolerable in my book.
Old Dec 18, 2024 | 05:49 PM
Roscoenancie's Avatar
We have front and back passenger and the front drivers side getting wet
we have front and back passenger floors getting wet and the front drivers side
Old Dec 18, 2024 | 06:06 PM
m05fastbackGT's Avatar
Consider the repair and service section subforums... Thread link is provided below!
https://themustangsource.com/forums/f739/
Old Dec 18, 2024 | 07:25 PM
05stangkc's Avatar
Might as Well Start with factory TSB and Then Rest of Repair section Especially Stickies as Advised Above!
https://themustangsource.com/forums/...26-7-a-550617/
KC
Also Moving This Thread To Repair & Service Section
glo106
Jan 7, 2017 04:50 PM
Brian Hood
Nov 9, 2015 05:24 PM
Doodad13
Jul 2, 2013 06:16 PM
wildfordchild
Feb 8, 2013 06:17 PM
Blue82
Feb 22, 2012 05:16 PM
