95 GT blower runs constantly
Old Feb 14, 2014 | 03:41 PM
hayman3347's Avatar
Talking 95 GT blower runs constantly
My '95 GT coupe HVAC blower seems to run on low speed even when the switches are in the "off" positions. What do you think the problem is?
Hayman3347
Old Feb 17, 2014 | 06:56 AM
td01gt's Avatar
Check the fan blower resistor.When they go out only work on 1 speed, low.
Old Feb 21, 2014 | 09:19 AM
hayman3347's Avatar
OK, where would I find this resistor?
Old Feb 21, 2014 | 09:26 AM
AlsCobra's Avatar
A Man Just Needs Some....
When the key is in the run position and car is not moving? When the car is moving you might still get air out the vents. Just wondering.
Could be a few things otherwise. Control panel, stuck relay maybe. I wouldn't suspect the resistor because it needs power to it which it shouldn't have. Without a wiring diagram I really can't help much more.
Old Feb 21, 2014 | 09:32 AM
hayman3347's Avatar
Yes, it blows when the key is in "on" position not moving. You can hear it :-)
Old Feb 21, 2014 | 09:36 AM
AlsCobra's Avatar
It also works on the other speed settings fine also right? I would probably pull the control head and possibly unplug it first. Does the fan setting **** have the off position or the mode ****?
Old Feb 24, 2014 | 09:03 AM
hayman3347's Avatar
Yes, it works fine in other positions. It has the "OFF" position instead of "MODE"
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
