94 gt squeak until pushing in clutch, and battery power goes low until I press on gas
Old Feb 20, 2011 | 11:50 AM
ceras1089's Avatar
My 94 mustang gt has a squeak until I press on clutch then it goes away til I release it.
It also lacks battery power til I press on gas, I have a new battery in it and the alternator is in working condition as I had it checked.
What are solutions for these?
I had it tested at advance auto parts.
Old Feb 20, 2011 | 04:32 PM
Onesickstang01's Avatar
Squeak is throwout bearing. Where did you test that the alternator is putting out enough voltage? Could be many things from battery to battery cables or terminals
Old Feb 20, 2011 | 05:19 PM
ceras1089's Avatar
I had the alternator tested at advance auto parts
Old Feb 20, 2011 | 09:39 PM
houtex's Avatar
Or, not knowing the condition and/or accessories in the car, a drain on the system. Maybe the idle's too low, or there's a big stereo, or underdrive pulleys or...
Not enough info to correctly guess, to be honest.
Old Feb 20, 2011 | 10:00 PM
ceras1089's Avatar
Idle is right where it suppose to be, I've only noticed because when I start the car the battery level is bout .25 way up then when I push on gas it goes up to .5, never matters if lights stereo or anything is used its only noticeable at idle.
Mpaps
Oct 11, 2017 08:06 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
