3v or stay 2v
3v or stay 2v
So the title pretty much sums it up should I go with a 3v swap 2,000 on ebay or stay 2v and build it. I know the stock hp on stock bottom end on the 2v is about 420 to 450 anybody know what it is on a 3v any advice or input is welcome thanks for any input
Originally Posted by Pete07GT
To my knowledge the stock inernals on the 3v's can handle the same amount of HP gains. 420-430 is about standard.
Originally Posted by cdynaco
Plenty of 3V's at 475-500 tops. But the 3V breathes better if all other components are brought up to speed. So getting there could be quicker than a 2V.
Gary runs 475 on Seven and several on that S 197 place are 475ish.
But now I'm hesitating and rwhp or flywheel....
Either way I don't think the internals are much different between the 04 & 05. But the 3V's 2 intake valves with the 1 large exhaust valve + VCT did bump the HP quite a bit. Stock Bullitt is 315 (flywheel) w/CAI/hoodliner. The 2V doesn't come near that right?
![Headscratch](https://themustangsource.com/forums/images/smilies/headscratch.gif)
1 Post
No matter what you do, building a mod motor isn't cheap. Stick with the 2V. For what you would spend for a new 3V, you could get a DSS or something shortblock and not have to worry about what it will hold. Plus the trick flow heads for the 2V are awesome
