02 sensor problems
First off... why did you take it to him I'm the first place? What was wrong with the car? Is there a check engine light?
If there is us new edge owners have a meet little trick we can do. With the key in the off position hold the trip reset button for 10 seconds, then turn the car on while holding it down still untill the guages go all the way up. Then hit the trip reset button to scroll through the options until you see "dtc0000" there should be a four digit number behind the "Dtc" or the word "none". If It does infact have a code google search it and find the problem. If it is an O2 sensor it will tell you the exact one.
The upstream o2 sensors are located on the hpipe right below the header. If its a v6 they're on the y pipe below the header.
They're an east fix.
Let is know what you find.
Rando
Aug 25, 2021 11:12 AM
