02 sensor problems
Old Aug 25, 2012 | 09:36 AM
2_CW_2's Avatar
02 sensor problems
Had my 03 GT checked and the guy say its my upstream 02 sensor!!! Anyone know where it's located???
Old Aug 25, 2012 | 10:25 AM
cpotts13's Avatar
First off... why did you take it to him I'm the first place? What was wrong with the car? Is there a check engine light?
If there is us new edge owners have a meet little trick we can do. With the key in the off position hold the trip reset button for 10 seconds, then turn the car on while holding it down still untill the guages go all the way up. Then hit the trip reset button to scroll through the options until you see "dtc0000" there should be a four digit number behind the "Dtc" or the word "none". If It does infact have a code google search it and find the problem. If it is an O2 sensor it will tell you the exact one.
The upstream o2 sensors are located on the hpipe right below the header. If its a v6 they're on the y pipe below the header.
They're an east fix.
Let is know what you find.
Old Aug 25, 2012 | 01:11 PM
2_CW_2's Avatar
Ya it's the service engine light. And I tried to tell his ******* it was on the h pipe Preciate the help bro
Old Aug 25, 2012 | 02:33 PM
cpotts13's Avatar
No problem.
Rando
Aug 25, 2021 11:12 AM
trackpack13gt
Jul 25, 2017 05:29 PM
boz
Oct 1, 2015 04:47 PM
