Starting problem
Old Dec 10, 2011 | 08:47 AM
jesse16's Avatar
Starting problem
I have a 2002 V 6 mustang and recently the car won't turn on it cranks but it seems that there is no gas going in to the engine... Anybody has suggestions???
Old Dec 11, 2011 | 11:18 AM
dcpirani's Avatar
Possibly the fuel pump...
Old Dec 28, 2011 | 11:19 PM
bradh2414's Avatar
gonna sound weird. check the trunk. theres a switch on the left side (at least on the 98 it is) called the inertia switch. It cuts fuel in case of an accident. check to make sure the red button is pushed down. if not then push it down. ive had it happen before and all i got was crank no start.
It that isnt it, then it will mostl ikely be the fuel pump
Old Dec 29, 2011 | 03:13 PM
jesse16's Avatar
Ok anybody know how much is the fuel pump??
Old Dec 29, 2011 | 03:36 PM
bradh2414's Avatar
I've been quoted around 200. But you can always find cheaper lol
Old Dec 30, 2011 | 07:40 AM
get a fuel pressure check gauge from autozone and check your pressure, or you can push the little check valve on the fuel rail and see if it spirts out any fuel.... or if it shoots out with any force. Best to check it with a gauge tho
Old Jan 2, 2012 | 08:12 PM
updates??
Old Jan 2, 2012 | 10:40 PM
jesse16's Avatar
Nope it started but it turn off it was trembling when it was on...
Old Jan 3, 2012 | 05:03 PM
ThatMattGuy's Avatar
Vacuum leak?
Old Jan 3, 2012 | 06:22 PM
I would think it would stay running with a vacum leak, not 100 % sure on that tho. Did it back fire at all? Did you check the check valve on the fuel rail for pressure?
Old Jan 3, 2012 | 06:26 PM
bradh2414's Avatar
So its not the fuel pump, the inertia switch, or vacuum lines? Idk what else it could be
Old Jan 3, 2012 | 07:03 PM
My 06 had a bad vacuum leak which caused the RPMs to go so low it shut off...but it was a tube connected to my supercharger and it was faulty so it's probably not common...
Old Jan 4, 2012 | 06:00 PM
possibly jumped timing? How many miles are on it?
Old Jan 13, 2012 | 04:08 PM
jesse16's Avatar
Yea i got it to start but it turn off it started to tremble and the turn off... It has about 110,000 miles
Old Jan 13, 2012 | 04:25 PM
check your timing
Mpaps
Oct 11, 2017 08:06 PM
DrisStang
Sep 14, 2015 06:20 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
jim010
Sep 7, 2015 02:40 PM
