Sound system help
Old Jun 9, 2004 | 09:58 AM
Lord Chabelo's Avatar
As a wedding present, my brother in law changed the system in my wife's convertible (a Mach 460) for a custom built one. Now I have the Mach at my disposal and would like to install it on my car. I still haven't seen what was removed from the Mach, but I know for a fact that I will need the speaker covers that are mounted on the window corners (I would like to get the exact same ones so I ayone can point me in the right direction). Does anyone have list of everything included in the Mach 460 system so I can compare it to what I have and figure out what I need? Did it come with amps and/or a base? Can ayone tell me where I could find info on how to take off the factory stereo on my car and install the Mach? If I do this myself will I void my warranty? Thanks for the help guys
Old Jun 9, 2004 | 10:14 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
one thing you are going to have problems with, there is alot of wireing that is included with the mach460 system that is not present with the regular. For instance you have 3 amps. One under the dash, 2 under the back deck and a simulated sub box for teh back 5x7 speakers. I think you'll be better off going with an aftermarket headunit and putting in your own better speakers. But i understand getting it for free.
Old Jun 9, 2004 | 10:20 AM
I am not afraid of doing the work, the wiring should be easy if I could get my hands on the wiring diagram (a BS in Electrical Engineering and MS in Computer Engineering should come in handy for once ) but I am concerned about voiding my warranty (I still got two more years on it)
Old Jun 11, 2004 | 09:39 AM
Ok, the only thing returned by the shop was 8 speakers and the stereo/CD changer. There were no amps nor sub box The thing is, my wife's convertible had two sub boxes and two huge amps installed. Did my brother in law get hosed? Any one got a pic of the Mach 460 amps and sub box?
Old Jun 11, 2004 | 10:09 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
they probably reused the sub box for the rear speakers (its not a real sub box, just a place to keep the speakers), and left the amps all in place. or they may be reusing the amps.
Old Jun 11, 2004 | 11:56 AM
I don't think the car has 5 amps and 3 sub boxes. The sound is very nice, but not that nice. The two new amps are pretty much doing all the work
Old Jun 14, 2004 | 11:40 AM
I called the dealer where my wife bought her car and they said the Mach 460 has 2 amps, 2 sub wufs, and eight speakers. The shop that installed the custom system said they left in the two subs and two amps. Is there a way I can confirm this?
Old Jun 15, 2004 | 02:56 PM
First thing's first. How do I switch out my stereo for the Mach 460's?
Old Jun 15, 2004 | 02:59 PM
Scothew's Avatar
Stubborn Bear
TMS Staff
i'll be honest, i've never tried to adapt a mach460 into a non-mach460 stereo. First thing I guess i'd start looking at is what all parts you have and what type wiring harness's you have and if they hook up to the parts you have.
Old Jun 22, 2004 | 10:00 AM
Where can I find out more about the wiring harness?
I have the Mach 460 stereo and its 8 speakers
I'll be happy if can switch the stereo in my car for, the Mach 460's, and ust keep the factory speaker set up for now. I need a CD changer bad!
Old Jun 29, 2004 | 10:36 AM
Help me forum members...you're my only hope
Old Jun 29, 2004 | 10:44 AM
JeffreyDJ's Avatar
Just so I understand ... at this point you just want to hook up the Mach 460 headunit into your current setup?
If that's the case, I really can't help at all, but I can try and search and see if another site as a harness diagram.
Old Jun 29, 2004 | 11:52 AM
Correct. I can't find anything so far. Thanks for helping :worship:
Old Jun 29, 2004 | 11:57 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
check http://www.crutchfield.com they should have the specs on both wiring harness's and can probably help you out.
Old Jul 1, 2004 | 09:51 AM
Thanks for the tip. I found a nice article that says I'm pretty much screwed since the Mach 460 uses 4 6"x8" for bass and mid bass, and 4 tweeters for the highs. Thanks to this peculiar set up its not cool to mess with the Mach 460
I guess I'll have to go to an audio shop to see if they can help me
Old Jul 1, 2004 | 02:40 PM
Does anyone have pictures of how the Mach 460 looks in a coupe?
Sep 16, 2015 06:44 PM
DrisStang
Sep 14, 2015 06:20 PM
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
