SN-94 Convert to Carbureted V6
#46
I work at a machine shop, we have air hoist and they're use to lifting 3. Tons so big help there whe work with ship blocks and housings, I plan to put the mustang on ramps and unbolt from the bottom need the proper technique
#48
#49
1 Post
Originally Posted by Blackout
That would be a badass swap though. Just make sure you research what your getting yourself into and that you can handle it.
#50
If you're wanting an aftermarket block this is the one
http://www.americanmuscle.com/frpp-boss302-block.html
#54
What mods can I do now for a gt swap that's my main goal.
Break booster, radiator and coolant tank, k member and new a arms, and wireing harness
Could I use my same key?
#58
1 Post
Its no problem. Before you start anything however, you need to figure out what you want, research, and plan for it. Otherwise, you'll end up wasting alot of time, money and parts. Theres alot that goes into to any swap, and knowing what your getting into and everything you need, will help speed up your swap and increase the probability that you get it done and not just get overwhelmed and sell off the project.
#59
1 Post
http://mustangforums.com/forum/5-0l-...nsmission.html
Just found this a minute ago. It details all the parts you would need to swap a fuel injected 302 into your car
