Nitrous vs 2013 5.0
#62
#63
1 Post
That's a really impressive video. Looks like he's running a 100 shot. And on a basically stock motor. Just shows you what is possible with a good suspension, tires, and a little bit of power. ![Headbang](https://themustangsource.com/forums/images/smilies/headbang.gif)
Nitrous acts a secondary fuel to help burn the fuel in the cylinders more completely. It has a lower combustion heat then gasoline so it ignites faster helping to burn the gasoline.
Propane does the same thing on diesels. Nitrous is bad for diesels so they have a problem with it combusting to quick.
#64
Bear Eats King...
Bear ****s Bone
Bear ****s Bone
Nitrous by itself isn't flammable. If i remember correctly. That's why the bottles don't have a flammable sticker on them. But when mixed with air and fuel it can burn to an extent.
#65
1 Post
Its not. Its considered an oxidizer.Basically during combustion, the Nitrogen and the Oxygen atoms split and the Oxygen then reacts with the gasoline during combustion.
Rando
8/25/21 11:12 AM
