Fix
Old Aug 12, 2011 | 09:39 PM
jesse16's Avatar
Fix
Wat is cat efficiently below threshold bank 2 mean anybody?
Old Aug 12, 2011 | 09:51 PM
yugoboss's Avatar
Usually means your cat is not doing its job. Should be the one on the right hand side.
Old Aug 12, 2011 | 11:26 PM
jesse16's Avatar
The catalytic converter that's the thing thats not workin
Old Aug 12, 2011 | 11:32 PM
jesse16's Avatar
Fix
What does the code P0430 I'm the check engine mean?
Old Aug 14, 2011 | 04:01 AM
Evil_Capri's Avatar
Merged your threads . .
Might also want to check your O2 sensor.
A quick search on google.com found the following (among a number of other threads.)
System Efficiency Below Threshold (Bank 2)
Top Indicates Bank 2 catalyst system efficiency is below the acceptable threshold.
Use of leaded fuel
Damaged HO2S
Malfunctioning ECT
High fuel pressure
Damaged exhaust manifold
Damaged catalytic converter
Oil contamination
Cylinder misfiring
Downstream HO2S wires improperly connected
Damaged exhaust system pipe
Damaged muffler/tailpipe assembly
Retarded spark timing
Compare HO2S upstream and downstream switch rate and amplitude. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S very slow and reduces the amplitude of those switches as compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly with increase amplitude, approaching the switching rate and amplitude of the upstream HO2S. Once beyond an acceptable limit the DTC is set
Old Aug 14, 2011 | 10:59 PM
jesse16's Avatar
thanks for the info....
Old Aug 21, 2011 | 10:34 AM
Onesickstang01's Avatar
Ford v6s all have a problem with cats. I have replaced so many of these things its unreal. Before you spend that money though you need to check for intake leaks. Do you have a lean code at all? If so most likely intake leak. If intake is sealed then you nees to put a vacuum gauge and read vacuum or use a temp gun and see the heat of the cat to determine if its bad
Mpaps
Oct 11, 2017 08:06 PM
Fedupdave42169
Oct 20, 2015 10:29 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
TerryD
Sep 28, 2015 11:48 AM
