delete power steering?
I drove it one time deleting the powersteering with a smaller belt, and I'm wondering if possibly I may of screwed up the rack if that's even called a rack but its the part that goes to the tie rods
Maybe this picture I found off the web can help, but see the stud with the nut? The whole rack moves sways when I steer, and you can tell most likely those nuts are loose... So should I just tighten those nuts up and it would be fine?
A manual rack doesn't feel like a power steering rack w/o power assist. yes it is tighter at really slow speeds but easier has you get going. I have driven 2 foxes with manual conversions not all that bad, get the thought of how a car feels with failed power steering out of your head . that said leave it for a track car no real gains to make it worth it .
But I wouldnt do anything to yours now, throw some thread lock on the bolts and tighten them and see how that goes.
What he said. Great for track car, not worth it for a DD. To do it right you need a new manual rack. MM also has a power steering setup that tightens up the power steering so it is not so spongy like it is stock. Thats the best way to go really.
http://www.maximummotorsports.com/st...roducts_id=446
This is the kit. They used to have one for 96-04 as well, don't know what happened to it. But you get a new pump that uses less engine power and improves the responsiveness as well.
It was around 800 bucks a couple years ago, so I would expect to pay over 1000 for it.
I recently installed electric power steering in a 1966 Mustang. I did not use a kit, I simply pulled a column style EPS from a newer GM vehicle and then spliced the unit into the original steering column.
The results far exceeded my expectations and the cost was less than $200. I designed a controller that automatically adjusts assist level based on vehicle speed, so that the steering feel is "just right" regardless of speed.
I documented (with pictures) how I went about this on a Vintage Mustang forum. If anyone is interested do a google search for "Best $200 mod ever (EPS)"
or
follow this link to page 7 where the details start: [URL=http://forums.vintage-mustang.com/mod-custom-forum/787114-best-200-mod-ever-eps-7.html#post6037649[/url]..
Any questions just ask.
or
Rando
Aug 25, 2021 11:12 AM
Cobiecane
Oct 23, 2015 08:44 AM
