Clueless n00b seeks rear end advice.
Old Jul 20, 2020 | 10:02 PM
ragbag's Avatar
Hi, folks. Recently picked up a '96 3.8 convertible for our kids (teenage girls). Since the car hasn't ever been registered here (Alberta), we're going to have to get through a fairly rigourous inspection in order to register and insure it. So we're working through the usual stuff - a bad inner tie rod end, seized brake caliper pins, etc. While working on the rear brakes, though, I noticed some end (axial) play in the axles. It's not a lot - I'm guessing about half a millimeter - but I don't know what spec is.
Can anyone tell me if this is okay, and if not, where to look for the problem? Is this going to be a diff thing?
(I spend most of my time wrenching Subarus, so this is somewhat of a change...)
Old Jul 21, 2020 | 06:46 AM
A little play back there is normal. Welcome to TMS
Old Jul 21, 2020 | 11:32 AM
ragbag's Avatar
Cool, thanks. Btw, this is the first time I've ever had to deal with these screw-piston calipers. Wotta PITA.
Before I forget, another thing that I need to sort out is a speedo that seems way out of calibration i.e. I think it's reporting about 20% slower than actual speed. It's not a tire size thing - that's the first thing I checked, and what's on there matches sticker spec. Where do I start with this?
Old Jul 21, 2020 | 02:28 PM
Bert's Avatar
next guess on the speedo calibration, is the rear gear ratio was changed and the speedo was not corrected to match . . . on the later years this can be corrected electronically with the "tune" but I'm not sure about your year
Old Jul 21, 2020 | 04:26 PM
ragbag's Avatar
Stands to reason, but given the car's history (at least, as much as we know) it seems an unlikely candidate for diff surgery. I'll keep it in mind, though. Fortunately, speedo calibration isn't part of this inspection, so I hope we can just get past it and deal with this problem later. Will try to learn enough about this ride in the short term to determine whether the software adjustment is possible.
Old Jul 28, 2020 | 07:24 AM
ragbag's Avatar
Now that we've been driving around a bit, I'm beginning to think it's just a defective speedo. It seems to vary in its inaccuracy, and the odometer isn't working either, so we're just going to replace it and see if it smartens up.
Old Jul 28, 2020 | 07:27 AM
Bert's Avatar
I am not sure when they switched from mechanical to electronic speedometers, but it sounds like maybe the gears are stripped and need to be replaced
Old Jul 28, 2020 | 07:37 AM
ragbag's Avatar
Probably - the odo is mechanical.
Old Jul 28, 2020 | 08:00 AM
I think this is an easy fix? Like unscrew the cable from the trans remove a cover and the gears are right there? .... I think... maybe?? You can at lease unscrew it from the trans and see how easy the cable turns with your fingers.
Old Jul 28, 2020 | 08:30 AM
ragbag's Avatar
Certainly worth checking before pulling apart the dash, but I'm still leaning toward it being in the display, since the speedo needle (while inaccurate) does come up properly while the odometer is completely still.
fdesalvo
Mar 29, 2013 03:52 PM
Mustangfreak
2012-2013 BOSS 302
27
Apr 30, 2012 11:12 AM
airforcedefender
Sep 1, 2010 03:59 PM
Rogue
Rocket City Mustang Club
Dec 9, 2008 04:53 PM
big_block
May 27, 2008 02:36 PM
