ac not blowing cold
Old Jun 11, 2014 | 11:48 AM
Ms.Stang 98's Avatar
Wink ac not blowing cold
Just changed radiator in my 98 mustang,now the ac not blowing cold air,was working good til car overheated,why I replaced radiator,has new compressor in it,replaced that 6 years ago,what should I check? Thanks..
Old Jun 11, 2014 | 12:50 PM
Are you sure the antifreeze is at the proper level? If your fluids are not up to proper levels things might not work properly. If your car over heated it might have thrown a code that needs to be reset. Maybe disconnect the battery for a minute or two that should reset any thrown codes.
Old Jun 12, 2014 | 07:29 AM
Thanks, I did not personally change out the radiator,had my mechanic friend,I'm hoping he didn't disconnect air to put radiator in,I'm out of town,but will be picking car up, what can I check for myself?as he won't be there,he said he put Freon in it,thinks I might have leak,I completely replaced the ac 6yrs ago,the car is in Florida,I've got to have ac! Help!
Old Jun 12, 2014 | 07:35 AM
My mustang is a 3.8 v6,it's 98,I just replaced the radiator after 16yrs,the fuel filter,s belt,New plugs,wires,the ac was redone in 2008,so don't know why the ac would not work,it was blowing cold up til we replaced radiator, I'm stumped here..
Old Jun 12, 2014 | 09:06 AM
slow.stang's Avatar
Not sure if it throws a code, but there is a sensor or something that will prevent it.
Glenn is correct, find out which sensor disables the AC when coolant is low, it could have gotten ruined by overheating or still be low.
Old Oct 27, 2014 | 03:05 PM
ChrisS_04_v6's Avatar
I once had this problem, and it was a simple as the vacuum hoses not being tight or fully on. My old 95 once had a corroded hose and i replaced it, which fixed it. So if it isn't a sensor as the others posted, try that?
Glenn
73
Apr 26, 2016 12:22 PM
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
billy y
Sep 24, 2015 11:48 AM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
