98 power windows not working!
That happened to me, take off your door panels and make sure your window motor arms are straight and not hitting anything, and this may sound crazy but make sure your window is still attached to the mechanism and in the trac, my window froze to my car and the arms pulled right off it and they got bent to hell and I had to replace the whole mechanism. If you have to replace anything hardtop windows and window motors are identical and are a direct swap for a convertible
seriously, don't break it, sounds like something is either bound up as some state or your not getting power to the motor unit(s), if its both motors good chance it will possibly lean towards a wire issue or the actual switch unit (driver side) which is where I would start with, test that the door switch unit is actually receiving power and if its getting power but its not functioning check that the switches are actually working, if they are not that is the issue, if they do continue down the line until you run into the components that have failed.
lakersfreak
Aug 12, 2015 01:52 PM
