3.8 swap with a 5.0
Old Dec 21, 2010 | 11:19 PM
joeleal19's Avatar
3.8 swap with a 5.0
I got a 2003 v6 mustang, i ve been wanting to procharge it stage 2 with an aftermarket cam, headers, bbk cold air intake and a cobra or mach 1 rear end, but I also want a 5.0 in my car cause I like the bigger motors and fast motor, will a 5.0 motor fit in my 2003 body style?
Old Dec 22, 2010 | 12:23 PM
Knight's Avatar
Needs to be more Astony
yes.
Old Dec 22, 2010 | 04:25 PM
edumspeed's Avatar
Legacy TMS Member Pr
It has been done quite a few times. It's a PITA but can be done. Check on sn95forums or at the corral. They're a ton of gear heds there. And why not a 351 instead of a 302. More cubes = more power
Old Jan 15, 2011 | 10:49 AM
Onesickstang01's Avatar
Alot of people have done it. It's as simple as pulling your motor out with k member and swapping fox k member right in with the 5.0 still mounted. You have to use the 03 suspension and bolt it up to the fox k member. If you go with a carb setup you really don't even need to do much wiring but the electrical system isn't that big of a deal if you go with the injection setup either
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Ray11
Sep 25, 2015 12:43 PM
Cdvision
Sep 5, 2015 05:22 PM
