2000 Mustang 3.8L Hard to Start when cold!
Old Nov 22, 2013 | 10:55 PM
Spencersa1's Avatar
I just started having problems starting my car in the mornings. The starter will turn over but the engine won't crank. It usually takes about 5 or 6 tries before the car starts and a few times the car would not start at all. Once the car is started I usually don't have any problems with it for the rest of the day and it runs fine. I checked the fuel pressure at the rail and it was at 30 PSI at idle and it increased to 35 PSI at about 2500 RPM's, I also left the gauge on after shutting the engine off and the pressure remained constant at 30 PSI. I am getting spark to the spark plugs and the plugs were replaced about a year and half ago. I have one code that was stored, which was a cam shaft position sensor. I have heard that the these rarely go bad and that it was probably something else causing this sensor to throw this code. I need to get this fixed ASAP, if anybody can help with this issue it would be greatly appreciated. Thanks
Old Nov 25, 2013 | 09:30 PM
LivinTheStangLife's Avatar
Starter or battery bad or weak? Mine had some trouble starting in our 9 degree weather the other morning. I could tell the fluids were pretty thick
Ecostang
Nov 3, 2022 08:50 PM
RRRoamer
Jan 19, 2017 05:27 PM
jc46002003
Apr 15, 2016 03:00 PM
Kestral
Jul 29, 2015 10:26 AM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
