Will cam know Mass Air from Carb on 5.0
Old Jun 19, 2004 | 02:35 PM
Fishhawk's Avatar
I'm in the process of adding a new Edelbrock manifold, heads, and cam to my 85 GT. Since my motor was the first year for the roller cam and last year for the Holley carb I am running into some confusing numbers regarding a cam. I have narrowed my choices to the Edelbrock 3722 roller cam or the E-303 Ford Racing cam. They both have the same duration and lift but say that they will only work with 86 and up EFI engines that have Mass Air Induction. My question is, how does the cam know the difference from a Mass Air EFI to a Holley carb? Crain and Comp Cams say not to worry about it then give me the hard sell trying to get me to buy direct from them. Any suggestions or advice would be greatly appreciated.
Old Jun 19, 2004 | 03:36 PM
mr-mstng's Avatar
The came doesn't know the difference. I'm wondering if the firing order changed on EFI engines. Anyone, Anyone, Bueller?
Old Jun 19, 2004 | 03:43 PM
Fishhawk's Avatar
The firing order is the same on all small block Fords.
Old Jun 19, 2004 | 07:57 PM
mr-mstng's Avatar
Nope, not all of them have the same firing order.
260/289/302 1-5-4-2-6-3-7-8
5.0L H.O. / 351 W 1-3-7-2-6-5-4-8
Old Jun 20, 2004 | 10:40 PM
conv_stang's Avatar
i would say it will work fine, just have to get the jetting set correctly for it to run smoothly. carb motor just dont have the computer to automatically adjust for changes. and even the 86-88 computer have a hard time with induction changes. all of the ford motorsport cams E303, B303 etc will work on carb motors. dont know about other manuf. but i would imagine they are comparable
Old Jun 27, 2004 | 07:22 AM
bob's Avatar
bob
Right, the cam doesn't care what sort of induction you have. The firing order is the main concern.
However EFI cams will probably idle a bit smoother. EFI is more sensetive to overlap and reversion into the intake than carbs are.
Old Jun 29, 2004 | 01:24 PM
svopaul's Avatar
Service Manager
The cam will work fine. I had an '85 GT Cobra(Canadian GT) and installed a '93 HO engine with a E303 cam and kept all the carb stuff on the car. Ran great, never any trouble.
You run into trouble when you get into computer controlled cars that fire the injectors based on the programmed firing order....with a carb it doesn't matter but you do need to have the firing order correct for the camshaft. The HO 5.0 uses the 351W firing order.
Old Jul 3, 2004 | 12:14 PM
saldoggs's Avatar
the warning on the cam is because mustang that have a speed density computer will not run correct with your cam that computer can not measure the amount of air entering the motor. you carb setup will work fine just make sure that you cheack your valve clearnce
May 3, 2026 05:42 AM
wallace
Mar 29, 2016 10:09 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
