whit smoke out tail pipe when engine warm up need help!
Old Nov 5, 2013 | 03:37 PM
red5.0's Avatar
Hey guy I got a 91 stang gt with a 5.0 ho engine I just got it for a project car. It blew whit smoke when I got it and smelt like gas so I replaced the injectors in it cuz they were leaking and dumping to much fuel. Well that fixed the gas smell to the exhaust but now it blows white smoke during warm up than goes away after its to operating temp. In need of some help if anyone has any info for me thanks.
Old Nov 5, 2013 | 03:38 PM
red5.0's Avatar
It also don't shift out of first gear.
Old Nov 5, 2013 | 04:46 PM
Fox85's Avatar
White smoke means there is water burning though the system. Which is most likely a blow head gasket. But if its only in the morning or warming up its ok. If its in the middle of the day or your car is already running at normal temp and white smoke comes out then its bad.
Old Nov 5, 2013 | 04:53 PM
HOSS429's Avatar
legacy Tms Member
you recognized the smell of gas ok .. if it is coolant it will smell sweet .. if it is oil it will of course smell like oil .. i dont know if a 91 trans still has a shift modulator on the trans but they can leak and suck fluid into the engine which will burn white .. may be why you only have first gear as well ... missing valve guide seals will cause initial smoke on warm or cold startup ...
Old Nov 5, 2013 | 08:47 PM
red5.0's Avatar
Its not a head gasket at least the exhaust don't smell sweet it don't really have a smell to it and its thick cloudy smoke. I have heard about the modulator but don't really know much bout it
Old Nov 5, 2013 | 09:04 PM
red5.0's Avatar
How can you test the valve guide seals without pulling the heads off?
Old Nov 6, 2013 | 10:08 AM
HOSS429's Avatar
legacy Tms Member
you have to pull the valve covers and look for missing /broken seals inside the valve springs ..
Old Nov 6, 2013 | 03:17 PM
red5.0's Avatar
Where is the shift modulator usaully located on the aod trans?
Old Nov 6, 2013 | 04:15 PM
HOSS429's Avatar
legacy Tms Member
i dont think an aod has one ... i`m not sure ...if it does it will have a vacuum line going to it near the rear of the trans ..
Old Nov 6, 2013 | 08:46 PM
red5.0's Avatar
Alright thanks
Old Nov 9, 2013 | 07:36 PM
osso12's Avatar
white smoke = water.
Blown head gasket, cracked heads, etc.
Now.. I have seen modulators on auto trannys cause smoke issues as well. Make sure your modulator is ok. IE, if the modulator is sucking tranny fluid instead of doing its job with vacum... it will smoke like hell. I have never had a AOD so not sure if it has a modulator.
FromZto5
Sep 30, 2015 05:28 AM
50Cal
Sep 17, 2015 06:43 PM
Bryanh24
Sep 16, 2015 08:31 PM
14Glassback
Sep 11, 2015 04:50 PM
Sep 10, 2015 12:44 PM
