Weight?
Old Mar 7, 2004 | 10:59 PM
00StangGT's Avatar
What does the 89-93 Fox weigh?? Some guy is trying to tell me 3500lbs (GT hatch) but all the info I've found has supported my findings.....
1989-1993:
LX 2-DR - 2724 lbs
LX 3-DR - 2782 lbs
LX Vert - 3081 lbs
LX 5.0/2-DR - 2894 lbs
LX 5.0/3-DR - 2961 lbs
LX 5.0/Vert - 3214 lbs
GT 3-DR - 3193 lbs
GT Vert - 3314 lbs
Old Mar 7, 2004 | 11:15 PM
BullittMustang50's Avatar
Dunno It should be on the inside of your door i think I'll check mine torrw if i dont Brad may know ask him!?!?
Old Mar 8, 2004 | 01:04 AM
hdwrench's Avatar
dunno...i always knew my 91, 92 LX 5.0's wieghed less than the GT hatchbacks... according to those #'s they were 299 pounds lighter... wow
Old Mar 8, 2004 | 08:03 AM
JeffreyDJ's Avatar
Combination of the door and all that extra plastic.
I don't see how the GT hatch could be 3500 pounds. Yours numbers look right, as the SN-95's weighed more. Someone with a GT Hatch needs to run out and check the tag in their door for us.
EDIT:
http://www.edmunds.com/used/1993/ford/must...idenav..6.Ford*
Edmunds had even a diffrent number. I chose GT Hatch, and that's what it came up with.
Old Mar 8, 2004 | 08:38 AM
00StangGT's Avatar
yeah I've never trusted Edmunds but this guy says he has stickers with them reading 34xxlbs (but he links to a page with Mustang Partol Cars)
Old Mar 8, 2004 | 08:56 AM
JeffreyDJ's Avatar
I'd expect a patrol car to weigh more for various reasons. Cage, Equipment, etc.
Old Mar 8, 2004 | 10:19 AM
DanS.02GT's Avatar
The weight posted on the door sticker is the maximum gross vehicle weight. This includes passengers, fuel, luggage, etc.
Old Mar 9, 2004 | 04:07 PM
ford1's Avatar
I have a 1989 LX 5.0 and they weight in at 2950-3000LBs
Old Apr 11, 2004 | 01:39 PM
88blueGT's Avatar
I have a 88 gt hatch and i was reading the replys so i went outside to check the door on the weight... it dosent sound right but its saying that its 4,198lbs.
Old Apr 11, 2004 | 02:55 PM
DanS.02GT's Avatar
That is the maximum gross vehicle weight rating. That is how much weight your vehicle is rated for, including passengers and cargo. Say your car weighs 3200lb. Then add approx 100 lbs for a full tank of fuel. =3300lbs. Then add 4 passengers @ 200 lbs each. Now you're at 4100 lbs. Put 98 lbs of luggage in the trunk, and you've reached the MGVWR of 4198 lbs. The car itself, however does NOT weigh 4198 lb.
Old Apr 11, 2004 | 04:44 PM
88blueGT's Avatar
Oh. Thanks for clearing me up on that. I knew that the car itself did not weight that much but I just wasnt sure what the number was refering to and that was the only number that was on the door. There were two other numbers but they were faded and I could not see them clearly. Thanks alot.
Old Apr 12, 2004 | 05:14 PM
DanS.02GT's Avatar
The 2 other #s are probably the Gross axle weight ratings- The max. load for the front and rear axles.
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
davelev213
Aug 27, 2015 01:54 PM
