water temp guage and dash bulb help
Well the LX is running good and looking strong but we have a couple of things wed like to get fixed asap.
Here they are:
#1: There is a bulb out right about the speedo and how do I get to it and what kinda of bulb do I need to use?
#2 The water temp guage is not working and we have no idea how to fix it.
Thanks.
EDIT:
What about subframe connects. Any info welcome.
Here they are:
Thanks.
EDIT:
Here they are:
Thanks.
EDIT:
Here they are:
Thanks.
EDIT:
As for the water temp guage I would 1st suspect an unplugged wire from the temperature sending unit. On a 2.3 its located on the driverside of the head back against the fire wall. Same side as the rear most intake pipe about two widths of a finger and a little down.
If you have V8? I can only guess from memory its near the thermostat at the front motor. Follow the upper radiator hose.
Back to the speed o cluster issue.
Maybe these photos will both help and inspire?
For the subs, I second the Kenny Brown option, they are top quality. Maximum Motorsports has quality stuff as well. Go with the weld-ins, the bolt-ons are less effective and can work loss with hard use.
I have a set of $50 standard length subframe connectors with the cross brace seat support on my car from Blue Oval Industries...I guess thats the same company who manufactured them too(?). I welded them on and they do make the car feel a lot stiffer and it doesn't squeak and rattle as much.
