Upgrade 85GT quarter windows...Help
Old Oct 14, 2008 | 05:03 PM
KEEP's Avatar
My 85Gt Hatchback has been suffering from pooly designed and leaking quarter windows for over a year. I have have stayed vigilant and did not allow any water to sit and so far no rust has started. I have replaced the quarter windows 4 times and still they leak. I have decided to install the 87-93 style quarter windows in a final effort to stop this leaking.
If any of you have done this upgrade to your 79-86 fox hatchback, please share some instructions and pics if you have them. I would like to see pics of a 87-93 hatch with the windows out so I can see where the mounting holes have to go. Did you make a cardboard template then drill holes or what did you do... Thanks a million.
ps: Dont mind the vert in the photo, thats my other GT. I am only talking about quarter windows in a hatchback.
Old Oct 14, 2008 | 07:31 PM
sgt d's Avatar
fwiw, i have never done this swap myself but i would think it can be done with minor effort. also the only swaps i have seen have been to fully swap the whole car to 87-93, i think your idea would look good. does your car have structural damage that is not allowing a seal?
Old Oct 14, 2008 | 07:37 PM
KEEP's Avatar
I am beginning to suspect that it does some damage that I cant detect with the eye.... Although I have always thought that 79-86 glass mounted from the inside of a seal is nuts to begin with. Ford probably figured that by the time a leaking window rotted out the floor, the car would be long since retired.
Old Oct 14, 2008 | 08:08 PM
sscobra's Avatar
It's pretty simple to do. The only hard part is having to weld at least a 1/2" strip of metal inside the qtr. window hole. This is so the front bolts of the 87-93 windows have something to bolt to. There is another option. I did this on a customers car who wanted it fast. I took the mounting hardware that holds the 79-86 window in and modified them to make anchors for the 87-93 windows. Worked great with no issues. However, to do it 100% correct, it needs the metal strip added. You will also need the roof trim rail moulding(see pic). Another thing to think about is the difference between the 79/86 to 87/93 interior qtr. panels. These must be changed also when doing the window conversion. IF the 79-86 ones are not change for the newer ones, there will be a gap between them and the later model style qtr. window. I will try to get pics tomorrow. I might also have most of if not all the parts you need if you decide to pursue this.
Old Oct 15, 2008 | 06:20 PM
sgt d's Avatar
this would be a good little project for you to do a how to...
CiniZter
25
Apr 28, 2016 05:41 PM
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
GeoWett
Sep 30, 2015 06:40 AM
M3hunter
Sep 10, 2015 09:26 AM
