Turn Airbag light off?
Old Aug 27, 2013 | 12:47 PM
Tyson30's Avatar
Anyone know how I turn off the airbag light. I switched to a tilt column and unplugged the airbag harnesses from the airbag brain behind the heater controls.
The light is on steady, can I just pull the bulb or will that give me a CEL?
Old Sep 12, 2013 | 02:03 PM
Leylah's Avatar
From: Born & raised NOR*CAL, now residing in Indiana
I need help with this too...for same reason... mine on occasion will have a constant beep as well but that only happens w/ the light is off, when it decides to blink the beep stops...weird
Old Sep 19, 2013 | 06:17 AM
Spaz's Avatar
The beeping is supposed to happen when the light should be going on but doesn't. It will be beep 5 times, 3 times in a row. When there is an airbag fault, you will get the light or the 15 beeps, I don't think you can have both at the same time.
JT_Kwik
Nov 29, 2022 01:45 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
DEPUTY62
Sep 12, 2015 11:12 AM
14Glassback
Sep 11, 2015 04:50 PM
Sep 8, 2015 10:45 AM
