Trick flow
Old May 12, 2013 | 02:32 PM
toad1206's Avatar
Trick flow
Does anyone know how much extra power a trick flow intake would cost and how much more power would it give me on my 88 GT? Thanks
Old May 13, 2013 | 07:14 PM
onebadvert's Avatar
Not a whole lot by it self. But once you do full hci you will see bigger gains. On a completely stock motor I would only expect gains of 5-10 hp. But with supporting mods you can see alot more.
Old May 13, 2013 | 10:07 PM
toad1206's Avatar
Awesome thanks. I will keep that in mind. I'm putting a t-5 back in it, the people I bought it from had tried to put an auto in it and didn't do a very good job. Then I need to find a three wire connector for the alternator. Havin a blast doin it tho
Old May 15, 2013 | 09:29 AM
skunk21's Avatar
slight gains like stated more in the upper rpm range and there will be a better throttle response feel. look into doing a mass air conversion if not already done for future modding. The trick flow top end kit is a nice matched kit for the sbf and makes a nice street motor.
Old May 19, 2013 | 01:48 PM
toad1206's Avatar
Thanks for the advice. In fixing the speedometer cable on the transmission side. Is it easier to just change the whole cable or is it just as easy just to change the end?
Old Jun 2, 2013 | 08:45 PM
Horus's Avatar
Not enough to feel with the butt dyno. It is however a slight increase and every little bit adds up over time.
Cobiecane
Oct 23, 2015 08:44 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
FromZto5
Sep 30, 2015 05:28 AM
Sep 10, 2015 12:44 PM
