Tilt column
Old Aug 22, 2011 | 01:23 PM
Leylah's Avatar
From: Born & raised NOR*CAL, now residing in Indiana
Tilt column
Is the 87 the only yr that has the tilt steering column?
Old Aug 22, 2011 | 01:52 PM
dcpirani's Avatar
My 85 has tilt
Old Aug 22, 2011 | 04:04 PM
watchdevil's Avatar
Among the Fox Mustangs 79-93, a tilt steering wheel was available until it got driver's side airbags in the early 90's.
Old Aug 22, 2011 | 04:49 PM
DynamicmustangGT's Avatar
1979- 1990, my 89 still has tilt and no air bags.
Old Aug 22, 2011 | 06:14 PM
Leylah's Avatar
hmmm well I was out at a yard & all of em i looked at didnt! & someone said only 87, so I was kinda stuck
Old Aug 22, 2011 | 10:30 PM
watchdevil's Avatar
It was an option for sure during all model years before the driver's airbags. Many cars produced simply were not optioned with them. Don't forget to look in other Fox platform cars besides Mustangs. The steering columns are standard interchangeable parts used on many models. The 1980-88 Thunderbirds, Cougars and Mark VII are abundant as are the older model Panther Crown Vic, Grand Marquis and Town Car. Other Fox platform cars include the Continental 82-86, LTD/Marquis 83-86, Fairmont/Zephyr 78-83, Granada/Cougar 81-82. If you find one with a column shifter you can just remove the entire shift shaft and lever and it is literally the same as the ones used for floor mounted shifters.
Also, if you find that you need to use a single turn signal/wiper/dimmer switch instead of the dual separate turn and wiper switch of the first Fox design, then the single combined switch will still fit the column.
I guess I know so much about this since I put a 97 Mustang dash in my 84 Tbird and switched it to an automatic floor shifter with interlock from a Mark VII, removed the column shifter and used 89-93 Thunderbird/Cougar squared off column trim and converted the turn signal/wiper switch to the later model single stalk unit swapped in from an 86 Taurus.
Old Aug 23, 2011 | 09:22 AM
Leylah's Avatar
Didnt know that! Thanks!
Guess Ill make another trip out there this weekend!
DoubleBlown
Sep 8, 2015 06:33 PM
aixguy
V6 Performance Mods
155
Oct 15, 2005 04:17 PM
HastaLaVista
Jul 26, 2005 03:08 PM
maucoin65
Nov 28, 2004 09:33 AM
kevinb120
Oct 21, 2004 12:27 PM
