Tach, Temp, Volt - Fuse Blows 91 Mustang
I have a '91 Mustang GT with about 200k miles on it.
I am the original owner.
The Tach, the Temperature Gauge, and the Voltage Gauge fuse is blowing.
I haven't installed anything new recently and the gauges and everything are all stock. The whole car is stock for that matter.
I pulled the fuse box and checked this weekend if there were any loose wires or apparent problems and found none.
I also pulled the steering column off and checked the wires there for anything loose or apparent but again found nothing.
Does anyone know what this might be?
Thanks for any help.
It might be behind the cluster, all it takes is a loose wire back there.. Put a temp relay in the from Auto zone or checker so you dont keep going through fuses while your checking....
