Stock Dif. Gearing?
Old May 28, 2006 | 07:01 PM
GT-Jim's Avatar
Question Stock Dif. Gearing?
umm can ne one tell me what the stock differential gearing is on a 1991 mustang gt? Just wondering cause my car doesnt seem to be taking off quick enough when i floor it
Old May 28, 2006 | 07:25 PM
Stix66's Avatar
I believe they are 2.73's.
What is your car doing? Building a ton of torque up at first and taking off?
I have an AOD '93 GT with 3.55 gears in the back it and thats what it does. Usually to get the thing to pick up quick is not to floor it and moderately get down on the gas pedal. I do not know if this is normal thought becasue I bought it with the aftermarket gears in it already.
Old May 28, 2006 | 10:51 PM
Valentino's Avatar
3.08s were an option, also. There should be a metal tag on your diff cover that says the ratio or there is a code on the label in your door jamb that i'm sure someone here will be able to decode it for you.
Old May 30, 2006 | 12:39 PM
93Cobra#2771's Avatar
www.mustanggt.org has a decoder for the door tag...
Old May 31, 2006 | 11:22 AM
GT-Jim's Avatar
thanks guys.. well i guess ima change the gearing and put them the same as my monte carlo... seeing as how ive burnt over 20 mustangs on takeoff.. im guessing ill put a little higher so... 3.73 or 3.77... Thanks again guys
Old May 31, 2006 | 11:38 AM
Go 3.73, you'll be glad you did.
Old May 31, 2006 | 02:03 PM
GT-Jim's Avatar
Yep thats what im going for
Old May 31, 2006 | 04:06 PM
gussy8055's Avatar
I went with 3.55's in my 90 GT with a manual , works allot better than the 3.08's that came out .
Old May 31, 2006 | 08:49 PM
Hotrod's Avatar
3.73s will make that car jump off the line. Ive only riden in a car witht he 2.73s but driven a 3.73 car. They're a whole lot better. As I like to say they make second gear "the happy gear" since it pulls like a mother!
Old May 31, 2006 | 09:56 PM
GT-Jim's Avatar
i know what u mean hotrod... like i said earlier my monte ss has 3.73 and it makes all the difference. i know its hard to compare my monte in its current state(545hp) to my mustang but even when it was stock the monte took off a whole lot quicker and had some serious gain... im going 3.73 with my fox and thats the bottom line!
Fastnloud
Feb 15, 2016 05:21 PM
samjluck
Sep 17, 2015 10:24 PM
M3hunter
Sep 10, 2015 09:26 AM
whowasthat
Sep 3, 2015 08:48 PM
