Starter help
Old Sep 23, 2011 | 01:34 PM
Fox90gt's Avatar
Starter help
Can anyone tell me why my stater is grinding never had the problem b4 but sinxe i put a new starter on it makes a horrible grinding noise
Old Sep 23, 2011 | 01:36 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Need to put a shim inbetween the starter and the bellhousing. Auto store will have one most likely.
Old Sep 23, 2011 | 02:48 PM
Fox90gt's Avatar
I habv shimed it and still grinding maybe bad starter not shooting the gear all the way out?
Old Sep 23, 2011 | 03:28 PM
Bear Eats King...
Bear ****s Bone
Might not have it shimmed it enough. If I'm right the starter won't engage unless the Arm is fully extended.
Old Sep 23, 2011 | 04:59 PM
Fox90gt's Avatar
I will try another shim thanks for the help
Old Sep 23, 2011 | 05:06 PM
Bear Eats King...
Bear ****s Bone
No problem.
Might take a couple shims to get it far enough back to stop the noise. Good luck
Also are you using a new starter or a remand one?
Old Sep 23, 2011 | 05:07 PM
polarisTXguy's Avatar
Shim it, I had a 289 that needed 4 shim plates to engage properly. If you want to know for sure pull back off and try and engage it with jumper leads to see if it is kicking all the way out.
Old Sep 24, 2011 | 08:11 AM
Fox90gt's Avatar
It new not remaned
JT_Kwik
Nov 29, 2022 01:45 PM
BigHoss
Sep 21, 2015 10:03 AM
